Help me make a list for Dropping Trans & New clutch
I need to drop the trans and take it to a place to have it looked at, as there is a marble like noise, while im in there I plan to put a new clutch assembly in as well.
Here is what I think I need for this project and have ordered already let me know if I will need anything else. Thanks
- Mccleod Single Disk
- LT4 Pressure Plate
- LT4 T/O bearing
- LT1 Pilot Bearing
- Plan to get the flywheel re-surfaced as well.
Do I need any gaskets? Bolts?
- LT4 T/O bearing
- LT1 Pilot Bearing
Re: Help me make a list for Dropping Trans & New clutch
Don't forget some brake cleaner to make sure the fly wheel surface is clean before installing the clutch and you should be good to go with all that you have listed.
Brake_L8
Jan 20, 2015 09:44 AM
Jul 4, 2005 05:00 PM
