Good sources for driveshafts
Here's the places I can personally recommend, just FYI. All three make excellent products at fair prices. Dynotech has very fast service.
Feel free to add your experiences. Denny's Driveshaft http://www.dennysdriveshaft.com/ Dynotech Engineering http://www.dynotechengineering.com/ Spohn Performance http://www.spohn.net/ Rich |
Re: Good sources for driveshafts
Cleveland Pick-a-Part I believe they can be found on ebay. They sell F-body, GTO, and Vette stuff online. Mostly 93+. They sell LS1 DS all the time. I bought my LS1 Front Brakes from them. They provided good product and service.
-Dustin- |
A1 Driveline in Baltimore, MD. Don't know the number, but they make great 3" steel driveshafts with the stronger no external grease fitting u-joints...Also get them thru www.fbodycentral.com...
--Alan |
I've heard good things. |
Big deal? Not in the least if it does its intended job well and I'd say it does. |
I have also heard good things about Dennysdriveshafts. Is the ls1 driveshaft far superior to the lt1? Or would it be more worth the time to buy one from dennys or something.
If you are using sticky tires on a prepped surface (i.e. the track) you should have a steel driveshaft, not aluminum.
Rich |
after the first aluminum comes out they will see but any way i had mine built at big moes in besemer alabama 3 inch steel tubing new 1350 slip joint on the front with solid body spiser joint and 1350 at the rear also mine had to be a custom lenth but it was only 258.00 my cost should not be much more for others though my freind busted a 9 inch housing and did not break the shaft like mine if any body lives around here
I picked up a used Dennys nitrous ready shaft recently and I have not installed it yet but it looks 10 times better than the 1LE shaft I have in the car now. Its BEEFY thats for sure, I don,t think I will ever come close to breakin that thing.
Very high quality product. |
I used Denny to make my DS, last year. After converting to a 12 bolt Moser unit, the DS typically requires work to shorten it, might as well replace it.
I ordered the 3" steel unit, going by the measurement required I got a peice that was cut to fit perfect. I had the recommeded 1/2" slip travel. VERY impressed the work. Only isssue was is that he is busy and I had to wait, but I understand, excellent craftmanship |
I'm using a Spohn Extreme Duty 3" CM made for a short tail TH400.
It fit well and is very smooth at 125mph and 6000 rpm. Just what I paid for. Dean |
Originally Posted by rskrause
The shaft seems to work great, but I have been sidelined with an oil leak and another swap. |
Originally Posted by Jameslt1TA
(Post 3623790)
http://i49.photobucket.com/albums/f2...driveshaft.jpg |
im putting a LS1 t56 and moser 12 bolt in a 90 camaro, do i need a new driveshaft, LS1 drive shaft, or should i order one! ifso let me know were to get it!
| All times are GMT -5. The time now is 01:18 PM. |
