GM 4.10 gears in 02 Z28
I am intersted in putting some 4.10 gears in my 02 Z28 (original 3.42 gears). I was looking at http://web.camaross.com/forums/showt...hreadid=261351 . I see that they have GM 4.10 gears for $159.95. Is that a good deal? Are they quality gears? I also notice people talking about 2 or 3 carriers. How do I know what I have and what gears will work with it? How about there install kit for $39.95? Thanks for any help.
Since you currently have 3.42's, then you have a 3-series carrier, thus would require 4.10's for a 3-series carrier
As far as I've heard or read on here, GM gears are supposed to have a good reputation for being quiet gears
. I just had Richmond 4.10's installed in my car (today, in fact
) and they have a very slight "whine" to them, although not very bad. However, I had a set of very "whiney" Richmond 3.73's last year
.....Richmond's tend to be a little noisey, but then again, I've heard that's because they're built with a higher nickle content to strenghten them??
.....back on topic, I think that seems like a good deal for gears, and with the M6, 4.10's will be great!
Sounds good to me. I just got a set of Used GM 4.11's and then $45 for a ratech install kit and another $18 for a sold pinion spacer. I did the install myself. Didn't have the marking compound, so didn't check the pattern, but they only have a slight whine at about 45. I plan on going back in and redoing the setup. They deffinitaly make the car pull bette.r
Originally posted by JoeMack
Any other opinions or experiences?
they are stronger than the 41pinion 10ring gears and are less likely to break from what i hear (just had a discussion on this about a week ago)
that's what i'm gonna do once i get the money
just a suggestion
Jul 4, 2005 05:00 PM
