CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   Driveshaft problems... (https://www.camaroz28.com/forums/drivetrain-44/driveshaft-problems-535418/)
96LT1TX Aug 1, 2007 04:39 PM
Every few times I go to the track I seem to get a soft vibration from the driveshaft yoke and get it re-installed at the drivetrain shop. They rebalance it, put new yoke on, and every time a new vibration starts. It seems that the yoke is coming loose? It is a stock driveshaft with the 12bolt yoke on it Anyone else experience these problems?
Injuneer Aug 1, 2007 05:30 PM
The stock steel DS's have a problem with vibrations. It was bad enough that there was a factory TSB issued, and some people were able to get free aluminum replacements while the car was still under factory warranty. Attempts at rebabalancing are generally unsuccessful. I believe the problem may have been caused by the input yoke not being concentric with the centerline of the DS.
Most people just opt for a 1LE or LS1 aluminum DS. On the other hand, with enough power to require the 12-bolt, you might want to consider an aftermarket steel DS, like the ones from Spohn or Dennys.
Moving to "Drivetrain"......
96LT1TX Aug 2, 2007 08:12 AM
I see, so there is a centerline problem, which makes sense with the problems I have had recently. The aftermarket ones you talked about, I will look into those and hope they arent "too" expensive.
