Difference between Ford and Chevy TKO600
Old Nov 3, 2008 | 09:22 PM
mpe331lx's Avatar
I recently picked up practically brand new Tremec TKO600. It came with an aluminum bellhousing, a billit steel SFI flywheel, and a 26 spline dual fricton SFI clutch (looks like a McLeod), all for a Chevy
The Tremec part number is a TCET5009.
Summit racing shows the TCET5009 as a Chevy TKO600, the ford TKO600 is a TCET5008.
Ford: TCET5008
Chevy: TCET5009
Does anyone know what the acctual differences between the two are.
Can the chevy based trans be used in a ford with the correct bellhousing.
I know that the ford based 3550 and TKO have been used in chevy conversions in the past, and am assuming that this may be able to be used in a ford application.
I want to KNOW, isnstead of assuming!
Old Nov 3, 2008 | 10:42 PM
mpe331lx's Avatar
http://www.ttcautomotive.com/English...090107_145.pdf
Looks like the input shaft and bearing retainer are the only difference!
Old Nov 3, 2008 | 11:15 PM
mpe331lx's Avatar
Did some more digging.
The case has a different mounting pattern and the output shaft has a different part number.
It looks like it is a chevy only trans.
cmsmith
Mar 11, 2015 09:55 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
formula79
18
Jul 1, 2002 02:39 PM
guionM
14
Jun 19, 2002 08:30 AM
