cruise control wont work.
ever since i got my new tranny put in my cruise hasnt been working. i have checked the plugs to my tranny and they are all hooked up. i wanna try and fix this myself but if worst comes to worst i guess i could just take it back to the shop that put the tranny in and make them fix it. what do yall think
Re: cruise control wont work.
Check the cruise control module, make sure the connections are good.
M6 or A4 trans?
Some people have fixed a cruise control problem by replacing the cheap turn signla lever. I guess they go bad over time. Just a thought
Where is the cruise control module located? |
yeah where is the cruise control module?
Check your third brake light. The cruise control is on the same wiring. If it's blown, your cruise control will not work.
P.S. cruise control module is, I belive, just above the K member drivers side forward. |
Yeah the brake light thing happened to me.
Im pretty sure the CC is the black box next to where the air filter goes on a CAI. Its under the plastic splash panel behind the air dam on the driver side. |
