convert or just buy 6speed
i love my car the way it is, i just wish it was a six speed... my old car was and it's hard to go to an a4 from an m6
should i just convert it later down the road? or just buy a 6 spd.
i eventually want to settle on the one that i am going to keep for a loooong time... so if i decide to trade/sell, i should do it now.
thanks for your input.
It entails alot of friends, alot of beer, alot of time, and alot of elbow grease.
Nah... it isnt THAT hard. I saw the swap done on a friends car. Most of it was done within a weekend. He said it was easier than he was planning for.
In Bristol, Pa theres a place called Contemporary Corvette (www.contemporarycorvette.com) they have lots of t56's in stock, give em a call
Originally posted by My Red 93Z-28
ROOSTER93V8 just did this swap, and I think Fastbird93 has also.
You can PM them, and I'm sure they would help you out.
As far as a kit, I believe that D & D Performance sells a complete kit, but don't quote me.
Something to take note of, if you don't have gears, GET THEM. My swap car still has 3.23's and is running a 95 T-56, and it's badly undergeared. Go to AT LEAST a 3.42 (stock for the 94+ M6 cars).
As for the swap itself, you'll need all the components. Tranny, clutch, flywheel, slave cylinder, master cylinder, clutch pedal, and misc stuff. There are some wiring differences, so have a good schematic or drawing handy so you know what you need to do.
Sorry I couldn't help more.
...sorry had to
As far as difficulty goes, have you ever done a clutch install? If so, then you are 90% done. The only other stuff you have to do is install the pedals, (easy even for me at 6'3" 385lbs - take seat out!),clutch hydraulics and shifter hole. That is the hardest part since there is a plastic cover on the floorboard you either need to take or cut out.
Think about it like you are doing a clutch/flywheel install. Then think you have to replace the clutch hydraulics, except the holes have been filled in. Think about it like you are doing a shifter install and they forgot to put the hole in the car.
Wiring is a cake job. 2 wires to get the car to start. Might take an extra 30 minutes if you wire up the reverse lights and clutch switch.
