| newbielt1 |
Sep 30, 2003 11:03 PM |
I also have a '94 and mine just went out yesterday with 108K on the good ol' clock. You gotta be careful because my clutch showed no sign of going out. It was not slipping at all, but it started to make a grinding noise, almost like two metal plates rubbing against each other when starting in first gear. The very same day it made that noise is when the clutch went out. When the shop took it apart I believe they said that the pressure plate was destroyed:eek:. I suggest you get it replaced sooner than later, keeping in mind that it's gonna have to be replaced anyways. Good luck and I hope this helped.
~~Wes
