Clutch problems NEED HELP!!!
Ok I just put in a Stage 3 and I took it for a test drive and everything was fine, then about 20 miles down the road it started making this really loud noise so I pressed in the pedal to release the clutch and the noise got even louder and the pedal was bounceing around and it stalled the car out, I started it back up and every time I press the clutch pedal to the floor it makes this really loud noise and stalls out. What could this be?
Re: Clutch problems NEED HELP!!!
OUCH!! Did you do anything else as far as the flywheel, hydraulic's or anything? pull your slave and take a peek w/ a flash light see if you have any scoring on the pp face.. if you do its your fork hitting. Check to make sure your fork is correctly aligned on there! its easy to misalign it and think it's fine..
Yup that is what it was my fork was being jammed into my pp housing(lots of scoring) but not because it was misaligned but because the throwout bearing broke 10 miles after installing, now I am going to have to deal with SPEC's warrenty Dept.
Just went thru the same ordeal..Springs fell out of disc so I pulled tranny and also found the TO bearing had broken also..
Cody |
| All times are GMT -5. The time now is 10:28 AM. |
