clutch install question
OK question. My throw out bearing inner diameter measures 1.330". My output shaft measures 1.300. Is this supposed to be a tighter fit? its a bit sloppy when i put it on. Thanks
Re: clutch install question
it has a bit of a wobble when i put it on the out put shaft
The TO bearing does not fit tight around the input shaft, not supposed to.
| All times are GMT -5. The time now is 07:47 AM. |
