can't get my tranny out!
every thing is loose from my M6 but its seized up against something, when trying to disengage it the engine moves as well. any one have an idea?
slide the clutch fork out?
might be seized around the pins. if thats the case then a few hits from a rubber mallet may work |
Are you sure you have all the bolts out of the tranny to bellhousing mount? There should be 8 of them.
finally got it, it was a booger! my clutch was so toasted one of the springs was somehow jammed into something.
