CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   bleeding the clutch (https://www.camaroz28.com/forums/drivetrain-44/bleeding-clutch-451307/)
cralarcon_IROCZ May 19, 2006 12:43 AM
bleeding the clutch
Does anyone know where the bleeder screw is for the t56
teke184 May 19, 2006 07:39 AM
Re: bleeding the clutch
driver side of the transmission...just above the hydrolic hose that goes in it.
find the seam where the trans bolts to the bellhousing...and run your fingers up...you'll hit the hose first...then above that (way up in the tunnel) you'll find the hole for the bleeder screw.
its a PITA to get to.
use a mity vac it's much faster
cralarcon_IROCZ May 22, 2006 12:07 PM
If i were to bleed the system not using a vacuum....how many times does it typically take to get all the air out the system? Also...when i was bleeding the clutch the pedal stayed down to the floor after opening the bleeder valve...should that happen?
teke184 May 22, 2006 03:08 PM
i've heard 50+ times...
and i don't think it's a big deal if the pedal stays down. there isn't any pressure forcing it back up.
cralarcon_IROCZ May 25, 2006 05:34 PM
One more question. What size tube will fit on the bleeder valve? is it the same for the bleeder screw on the brake calibers? Using a vacuum...how much pressure should be used?
teke184 May 26, 2006 07:27 AM
bout half way down it describes how to use a vacumn
