B&M Trans cooler installed but have a question
Subscribe
Aug 20, 2011 | 03:44 PM
I just want to make sure I did this right. The return line from the the radiator to the trans is the port on the bottom of the radiator correct? I saw a line on top and bottom and just assumed that the flow of trans fluid went into the top and out of the bottom.
Also if anyone has a picture of there trans cooler and how they routed the hoses id really like to see that thanks!
Reply
Aug 20, 2011 | 04:18 PM
Do yourself a favor and pull the factory line off the radiator put a bag over the end and start the car to verify that is the supply line. Ask me how I know.. Put a tranny cooler on my typhoon with a remote spin on filter with tranny temp gauge. Was told the top was supply and it was not. The bottom was the supply line and the spin on filter had a one way valve preventing flow...result.. burnt up clutches. Not saying that is going to happen just verify it will only take an extra two minutes when you take it off.
Reply
Aug 20, 2011 | 11:27 PM
Re: B&M Trans cooler installed but have a question
Quote: I just want to make sure I did this right. The return line from the the radiator to the trans is the port on the bottom of the radiator correct? I saw a line on top and bottom and just assumed that the flow of trans fluid went into the top and out of the bottom.
Nope, the return line is the upper line.
Reply
Subscribe
