CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   autometer trans temp install (https://www.camaroz28.com/forums/drivetrain-44/autometer-trans-temp-install-515552/)
slicknick54 Apr 17, 2007 10:50 PM
How do i install a electric trans temp gauge . do i drill a hole in the pan? Thanks again
2000GTP Apr 17, 2007 10:55 PM
This is a good place to put the sending unit: http://shbox.com/1/a4_plug.jpg
slicknick54 Apr 17, 2007 10:59 PM
is that there on the 97? thanks for all your help lately
2000GTP Apr 17, 2007 10:59 PM
It shouldn't be any different.
Moshbmx1 Apr 17, 2007 11:01 PM
Should be the same, thats the same spot im mounting mine
slicknick54 Apr 17, 2007 11:02 PM
how did youy guys tap into your illuminating wire>?
slicknick54 Apr 17, 2007 11:26 PM
When i install my two gauges what fuse do you guys wire them to and where do you wire them so they light up. where can i also find paint to paint my pod the same as my interrior. (sorry for the questions i just want to know the right way the first time)
2000GTP Apr 17, 2007 11:46 PM
You need a 12+ volt switched ignition source which you can pull out of the fuse panel block on the side of the dash to actually power the gauges. As for the ground, you should be able to find a bolt or screw that is screwed into the chassis sheetmetal. Once you remove the panel that is below the steering wheel, you should find a couple. As for the gauge lighting, there are a few sources you can pull from the dimmer circuit fuse in the fuse block, the headlight switch, or the instrucment panel dimmer switch.
ttop1986 Apr 18, 2007 01:09 AM
I remember reading that the test port on the tranny, will give you the reading of the case temperature rather than the fluid itself, because the fluid doesn't reach all the way up there. Not sure that makes much of a difference, but I am going to put mine here:http://ken.lowrance.com/projects/Tra...onOfSensor.jpg
a writeup here http://ken.lowrance.com/projects/TransCooler/
