aluminum driveshaft
Old Nov 19, 2007 | 09:14 AM
BCook839's Avatar
aluminum driveshaft
Did the A4 LS1 98'-02' f-body cars come with an aluminum driveshaft? If so will it fit on my 96' A4 LT1 camaro?
Old Nov 19, 2007 | 09:44 AM
teke184's Avatar
2.73 equipped LS1 cars had steel
3.23 equipped LS1 cars had alum
all driveshafts from 83-02 are interchangeable....v6, v8, 3rd gen, 4th gen, LT1, LS1, alum, steel, auto, manual....all the same.
biggest difference is the 4th gen v6s had a 2 piece shaft...so you'd need som extra brackets i think...but it would bolt up fine. not that you'd ever want one on a v8
Old Nov 19, 2007 | 07:23 PM
The Engineer's Avatar
I had a custom heavy-duty aluminum drive-shaft built locally w/ 1350 yokes (top). The one on the bottom is a stock LS.
WD
Old Nov 26, 2007 | 08:08 PM
sn8ke eatr's Avatar
i could be wrong but didnt a few fbodies leave with turbo 350's in the early 80's?if so they had different legnth driveshafts.
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
