Adapting M12 to my Camaro
I am buying a t56 from a 06 GTO to put in my 74 Camaro. The shifter set-up is different from a T56 from an F-Body. Does anybody know what I need to convert it? Just a tailhousing? If so, any ideas where to buy one?
Thanks for any help.
Is it going on an Gen I SBC? If so you will also need a different bellhousing and the input shaft will need to be changed as well. You will need a different tailhousing that supports a cable driven speedo (if you are using your stock speedo).
10-31-2016 11:09 AM
