A4 to M6
Old Jan 24, 2008 | 11:44 PM
thegift1's Avatar
A4 to M6
I'm hoping that you'll aid me in my dilemma. I own a '94 Trans AM GT that currently has a 4L60E tranny in need of a rebuild (stopped shifting beyond 2nd). I have toyed with the idea of converting my 4L60E to a T5 (which I've heard is one of the better manual transmissions). Would you'll recommend a change and what do I risk making such a conversion?
Old Jan 25, 2008 | 12:30 AM
Green96Z's Avatar
You mean a T56? The T5 is a 5-speed for the V6 F-body, the T56 is the 6-speed for all the V8's. Use the search option at the top, many owners on this forum have done the T56 swap. I did it myself and can say it is my favorite mod.
Old Jan 25, 2008 | 02:00 AM
thegift1's Avatar
T56 is what i meant.
Old Jan 25, 2008 | 11:50 AM
Jon94Z's Avatar
I'm about to start the swap myself.
http://www.afrashteh.com/tranny_pics/T56.htm
Old Feb 10, 2008 | 08:49 PM
Cool ZR's Avatar
If anyone planning to do the swap has to pass an e-test, I can save you a pile of grief. Do not connect up the wires to enable the hatch. If you do, it tells the car it's in park or neutral and as a result doesn't call for the EGR valve to open and you fail the e-test.
Old Feb 11, 2008 | 12:55 PM
95mysticta's Avatar
ill be starting my swap soon aswell... going to hate the install but going to love the outcome cant wait for the day its ready for a road test!
Old Feb 11, 2008 | 05:57 PM
Green96Z's Avatar
Right. You need to wire up the hatch release differently, and it's actually very easy. Simply use an inline splice to wire the orange wire from the 6-pin A4 connector to the tan wire going the the e-brake switch in the center console. Then the hatch only works with the e-brake on, just like a stock M6 car.
Old Feb 11, 2008 | 06:09 PM
1997whitez28's Avatar
Might be your shift solenoid
I had that problem in the 97 camaro at 140,00 miles I now have 160,000 running like a champ. It would go to 2nd then it would start redlining and would shift past 2nd. GM revised the Shift solenoid from what a tranny place told me. It cost total 50 or 100 bucks forgot. Punch is under 39 MPH and it shifts to 1st and fish tails everywhere and all you smell is burnt rubber mmmmmmmm
Old Feb 11, 2008 | 06:24 PM
Green96Z's Avatar
Uh, wrong thread maybe?
