98 3 channel rear into a 97
Old May 24, 2013 | 07:07 AM
93TAWicked1's Avatar
What about a 3 channel 98 Rear into a 97 3 channel car. I have the opportunity to pick up a 98 3 channel rear with 3.42's complete brake to brake cheap. It would give me better gears and LS1 rear brakes.
Will the swap work with the abs and brake lines, I do not want to get rid of the ABS?
THanks!
Old May 24, 2013 | 07:39 PM
rngilliland's Avatar
Re: 98 3 channel rear into a 97
It is a direct swap. You need the parking brake cables from the 98. Use the hard lines that come on the 98. It will work with your abs.
Chet1185
Feb 4, 2015 09:51 PM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
Brian Demeter
Aug 17, 2002 08:07 PM
