96 M6 Z28 3.42 Gears (Rearend Question) HELP!
Old May 7, 2007 | 11:32 PM
Mike96z's Avatar
Alright, went to the track, never had this problem before, usually when I burn out on my regular tires both spin and I never see one stop. Now I know sometimes the posi will transfer torque to one wheel. Okay so heres the story, went to the track and I just started to run slicks, 10bolt with 3.42s. I heat them up, okay all looks good, but then another time I did it the driverside rear tire stopped while the pass side one kept spinning, then my right tire spins on the 60'. Is this a prob with my diff or is it normal? How do I know I have a posi, always thought I did.
Old May 8, 2007 | 12:00 AM
Daniel6718's Avatar
one tire spining without the other its the posi!
you need another one...or just weld it up since its a racecar
Old May 8, 2007 | 12:34 AM
Mike96z's Avatar
So are you saying my posi is bad? Or I just need a better one? It hasnt given me any probs, dont wanna weld, it is my daily driver too.
Old May 8, 2007 | 02:03 PM
Daniel6718's Avatar
its gone
Old May 8, 2007 | 02:36 PM
Mike96z's Avatar
Gone, so in other words the posi is not going to spin both tires all the time or when I put alot of torque behind it? I was wondering why I was spinning the hell out of the soft compound 10" slicks. So that is the whole problem huh? Whats a good pose? Eaton?
Old May 8, 2007 | 02:37 PM
Mike96z's Avatar
It doesnt do this all the time, only did it with the slicks on when heating them up and then after I launched with slicks heated.
Old May 14, 2007 | 09:04 PM
Rob1997ta's Avatar
RPO description
Look for the RPO tag on the drivers door this is the sticker with all the 3 digit numbers and letters. You need to look for a G80 and that is a positraction, limited slip.
Old May 14, 2007 | 11:33 PM
LastBreedLS1's Avatar
i just wanted to know if it would be wise to buy 3.42 gears in used condition. he claims he ran them for like 2 months has the GM# on them, they look good no scrathes or cracks should i get them?
Old May 15, 2007 | 08:17 AM
Mike96z's Avatar
And if it doesnt say that?
Lastbreed: Yes id get them, as long as there are no chips on the teeth and everything thats fine.
Old May 15, 2007 | 02:09 PM
2000GTP's Avatar
If it doesn't say it, then it doesn't have that option.
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Dec 27, 2014 10:06 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
SLIMJIM
Jan 7, 2003 11:06 AM
x7x7
Aug 15, 2002 06:49 PM
