94' Rear-end re-build, am i missing anything?
Ok, so my car has near 150,000 miles one 'er, and the stock diff is definately tired, 1 wheel peel on slick surfaces is its new habit. Also it sounds like a jet flying by with all the rear-end noise. So, my plan is to put in an Eaton posi 3-series carrier (already purchased), 4.10 gears, and while i'm at it, have new HD u-joints put on while the driveshaft gets balanced. My question is what all should I expect to buy to complete this. Some people say re-use the bearings on the pinon...is this a good idea? Or should I plan to replace all bearings with new. I'm told i can buy a shim kit for relatively cheap, so i'll prolly do that locally. I'm going to purchase a Hypertech programmer to take care of the ecu, so the A4 cooperates, and other than that I'd just like to know if I have my bases covered. Thanks,
Re: 94' Rear-end re-build, am i missing anything?
I'm planning on using all BG fluids. Do you guys recommend buying the Master Install kits that come with all bearings, shims, gaskets, etc. or would a basic install kit suffice?
I'll get the full bearing kit. Yeah, BG they make some pretty high quality fluids...My brother's a Tech at a GM dealership here, and recently a BG rep came buy, now they are a distributor for them. Its pretty spendy crap, upwards of $20+ a quart depending on what you buy. But he gets cut "special" deals, and he has a couple 15 gallon drums of Gear Oil, also a wide assortment of Tranny Flushes, Coolant Flushes, each like 50 bucks per lil can i think, but it'd be all free to me, so I figure why not.
Originally Posted by OBE1 95Z28
4.10 gears with an A4...I guess you like high rpms
I think traction will be non-existent in first gear with that gear ratio. My friend's got 3.42's in his A4 and he can barely get it to hook on the street. If it's a track only car, that's a different story.
tommalcolm
Sep 11, 2015 03:39 PM
