93 Gear swap questions?
I have a 93 3:23 car and i just got 3.73's with a instal kit. What is EVERYTHING that i need to get my speedo correct??
Re: 93 Gear swap questions?
I think all you have to do is buy the dakota digital speed-o calibration box. I forgot the website but if you do a search for "Dakota Digital" you would probably find it in a post I did a while back with the link to the website where you can buy it.
Good luck. ~Kevin |
if have the a4 you need to get trans speedo gears from tci they have a chart
on line that will tell you which gears you need. :cool: |
where can i find that chart?
www.tciauto.com from there go to components and you will find the speedo gear section
I just had pcmforless burn me a chip to recalobrate for my gears. If you have an auto you'll need to change out the speedo gears though.
