700r4 problems
Old Nov 10, 2006 | 05:14 PM
redbird92's Avatar
700r4 problems
my trans in my 92 firebird has a small problem. maybe you guys will help me. when i put the car in drive, it hits really hard. as you drive it, the revs will be between 2500-2800 before it shifts into second. and the same thing for third and fourth and dont know about lockup because im not going to go that fast to find out. has this happened to anyone before? the trans is stock and the torque converter is stock. thanks guys.
Old Nov 10, 2006 | 05:53 PM
Dennis93TA's Avatar
Sounds like a sticking valve
Old Nov 10, 2006 | 08:16 PM
redbird92's Avatar
do you know if that means a rebuild or a flush? i just want the thing to shift right and not at 2500 rpms. thanks guys
Old Nov 10, 2006 | 08:47 PM
byrons1502's Avatar
check the throttle valve cable at the throttle body. if you disconnect it pull the cable out to see if it sticks. if it sticks take the cable out of the transmission(8 or 10 mm bolt) and pull the little metal rod up and down. it should want to pull itself inside the trans. it sounds like a bad throttle valve(tv) cable,stuck governor,stuck tv valve inside trans
Old Nov 10, 2006 | 09:27 PM
redbird92's Avatar
ive tried the tv cable at the trans and it does go down with some spring retention and the cable isnt binding. dont know about the governor or anything internal.
Old Nov 10, 2006 | 09:31 PM
byrons1502's Avatar
the governer is on the back of the trans and is a large cover that you pry off with a screwdriver. pull it out and clean it with brake clean very good. a good adjustible one also help if you need a new one. if the part in the tranny moves easily most of the time the valve is good
Old Nov 10, 2006 | 09:34 PM
byrons1502's Avatar
transmissioncenter.net
Old Nov 10, 2006 | 09:35 PM
byrons1502's Avatar
they can get you the best parts for your trans. i would recommend them to anyone with a 700r4
Old Nov 10, 2006 | 10:21 PM
Dennis93TA's Avatar
I bought a convertor from them. It worked great!! Great Peeps
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
Cam's maro
Dec 28, 2014 09:30 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
