700r4 with electric plug on side = lockup?
Old Aug 18, 2003 | 10:03 PM
Timberwolf's Avatar
Just checking to be sure. and what do I need for making the lockup solenoid function? Can I run it off a window or rpm switch?
I'm thinking I could use a momentary pushbutton on the shifter to make sure it's in third or higher as the trigger for the window switch. Then the window or RPM switch would send the signal to lockup the trans at the given engine speed.
Old Aug 18, 2003 | 11:37 PM
OneFlyn95z28's Avatar
it all depends on what wiring is inside
it is easy enough to do what you want
Jazsun
Dec 29, 2014 12:14 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
