4L60e will not engage in park??
Just like the title says. I have a 94 LT1 that I just built and it has a 4L60e tranny. I put the car in park and it continues to roll back. When I put it in drive it works just fine. Need help with the park situation.
Thanks Chris |
Well the linkage could be miss adjusted but more than likely the two bolts that hold the park paw in place are loose or missing. I would check the linkage first then I would drop the pan and look at that.
Ok I will try that. IM thinking that the linkage may not be tight. Becuase I just kinda thru it in there
Chris |
Definitely agree on the linkage. Same thing happened to mine, one night I heard a clunk getting on the highway. By the time I got home couldn't select any gears, turns out linkage got loose somehow.
Its Fixed!!! It was the linkage. It way too loose. Made a big difference
Chris |
