CamaroZ28.Com Message Board
-   Drivetrain (https://www.camaroz28.com/forums/drivetrain-44/)
-   -   4l60e problems (https://www.camaroz28.com/forums/drivetrain-44/4l60e-problems-870580/)
mutlyi4 Dec 6, 2012 03:55 PM
4l60e problems
ok my trans is giving me problems i have no lockup and if i go wide open throttle from a slow rolling start my rpms go to 7k so my guess is its slipping so my problem is the fact that I'm on a budget now first off let me say I'm no noob when it comes to turning wrenches been a mechanic my whole life but i have never rebuilt a trans before how hard is it to rebuild the 4l60 what would i need to replace is there a good manual i can buy on how to rebuild it any info would help greatly thank you
RUNMYTA Dec 6, 2012 04:37 PM
Re: 4l60e problems
I would start with changing the filter. I had some of the same issues. IF the tranny is starving for fluid due to clogged filter, the converter will not lock.
mutlyi4 Dec 6, 2012 04:53 PM
Re: 4l60e problems
filter was just changed about a month ago and fluid is still pink and does not smell burnt
12SCNDZ Dec 8, 2012 08:49 PM
Re: 4l60e problems
The ATSG 4L60E manual would be a start. I will tell you up front that the 4L60E is NOT a beginners transmission. The ATSG manual will instruct you how to assemble it back to stock, but these transmissions need certain parts changed/updated/modified.
Frank
mutlyi4 Dec 9, 2012 11:42 AM
Re: 4l60e problems
any suggestions on what to upgrade/replace as right now i cant afford to have it done and i need the car running my dad has rebuilt a few autos back in the 80's so he will be helping me i just need to know what common problems are and how i can correct them thank you
