4L60E help
4L60E help
I'm going to be tearing my trans out of my 95 Z28 in a couple of weeks. I was wondering if anyone has a link to a site that gives a step by step set of directions. Thanks in advance.
-Dave
-Dave
Re: 4L60E help
I used Javier's converter install instructions and just made sure the car was up higher, so I could get the tranny out from under the car..
Re: 4L60E help
I just took mine out, had it overhauled and reinstalled it. Not too bad a job. I left the exhaust in place, and let the engine just hang from the engine mounts. I got the top 2 bellhousing bolts out from the top before raising the car up. The other ones are pretty tight to the firewall but came out. Get a 12 point 1/4 inch drive crows foot for the tranny lines they are tight to get to. And be carefull unplugging your wire harness I hear its expensive to replace. Once the trans is dropped down some you can get at it easier...
Re: 4L60E help
Thanks for the info guys. I am going to have someone helping me who actually knows what theyre doing unlike me. I was just looking for a step by step kind of thing so that I have an idea of what exactly we're doing and could try to help more. Thanks again.
-Dave
-Dave
Re: 4L60E help
Originally Posted by FivePoint7z28
Not exactly what I was lookin for. Thanks anyways though. Nobody else knows any other links?
-Dave
-Dave
I know of many links, just tell me exactly what you need and I can probably find it. But the one I showed above was pretty good.
Re: 4L60E help
Originally Posted by 1SlowFormula
Then what are you looking for? This is a pretty detailed step by step that includes bolt sizes, pics, and everything. Steps 1 - 9 get it out of the car and the remaining steps put it back in, and and it even tells you how to check the fluid level when your done...
-Dave
