3.90's for a 2 series carrier?
hey guys im just swapping my 94 formula over from a4 to m6 and i want to change out my gears from 273s to 390s or 410s dont really matter. i know there are some placed out there that make lower gears for the 2 series carriers.
can someone point in the right direction here???? thanks! |
Motive gear makes up to 3.73 that is machined thicker for 2-series carriers, and richmond has them up to 3.73 also. If you want to go 3.90/4.10 you would have to use a spacer for $50 which motive gear makes for your rear. The only other option would to buy a new carrier for the 3.23 and up gear (3 series carrier). I hope this helps and also motive gears run alot quieter than richmond which run noisey no matter how there set up
.http://www.ls1speed.com/catagory.cfm.../%20Driveshaft |
| All times are GMT -5. The time now is 01:42 PM. |
