3.90 Gears... Any feedback Thanks
Old Jul 13, 2011 | 11:28 AM
manfire1987's Avatar
Would like to get some feedback on this gear ratio as I know its not your "common" gear ratio... Some feedback form someone who has ran them in a 6spd would be great here is the actually part I am thinking of running... Thanks
http://www.summitracing.com/parts/MGR-G875390/
Old Jul 16, 2011 | 09:12 AM
Kevin Blown 95 TA's Avatar
Re: 3.90 Gears... Any feedback Thanks
I don't have one, but what is your reasoning for changing your gearset only 4%? I could see it if you needed a little more at the track or something to not have to shift one more time, but that seems like a lot of trouble to go through for such a small gain. I'm not saying that would be a bad gear ratio - it's probably a very good one for the average 6 spd performance application.
Old Jul 16, 2011 | 09:30 AM
I actually have stock at the moment 3.42,and doing my research I would like 4.10, but that's little to much as I wanna drive on street 3.73 was choice tell I found the 3.9 0
Old Jul 16, 2011 | 09:40 AM
As well as the weak stock rear end don't wanna run 4.10 so figured maybe the 3.90 could be a happy medium
Old Jul 16, 2011 | 10:41 AM
jcl69cam's Avatar
I have 4:10's in my 6-speed Z, I run the highway speeds of 70 mph at 2000 rpms with stock size tires. What size tires are you going to run? 3:90's should work great, 4:10's are good too.
Old Jul 16, 2011 | 10:44 AM
How do you drive on them do you feel confident that your not gonna break anything I am running at moment 17,inch torque thrust will be running stock size on street pro stars on strip what brand gears you running the nosie???
Old Jul 16, 2011 | 10:51 AM
One more question how is your top end with the 4.10s. Ie top speed ..
karpetcm
Dec 16, 2015 09:07 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
karpetcm
Aug 14, 2015 03:02 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
kissel
Classic Engine Tech
Aug 10, 2002 04:04 PM
