2 step w/ 4l60e?
well, im not an expert on it, but you wire it up so that when your brake pedal is depressed fully, the 2-step is engaged.
So while the brake is all the way depressed and the 2-step is engaged, u are free to get on the gas, bringing it to the 2-step limiter as long as your stall is high enough, and your brakes will hold.
I run one on mine. So far the chassis can't react as fast as the 2 step does as far as load/unload. For a turbo w/auto maybe a T-Brake would be a better choice though. It would allow him to build boost faster.
except im not spending $600 for a rossler t-brake for a 4l60e. I refuse to get rid of my overdrive, therefore the 4l60e or a 4l80e will always be in place unless i swap in a 6 speed.
How is anything going to unload. For example with a 3500 stall and the limiter set at 2800 with your foot planted on the floor and the rpm constant at say 2800, at least with a Harlan 2 step it is constant, how does it unload?
It will work to get him spooled but not for shocking the chassis and tires to get that hard bite you're looking for on the launch. It's been tough dealing with these transmissions all these years just to have the overdrive and get reasonable mileage on a street/strip car. Wonder how it's going to be for the guys with the 6 speeds.
As far as I know you don't have to shock a chassis to get the tires to hook. Maybe my car is too slow but I brake torque to 2500rpm and dead hook drag radials, pulling the tires about 8'', and get high 1.4 to low 1.5 sixties. No shocking involved.
boost or not, how do you use a 2 step without a tbrake on an auto?
