1997 z28 30th anniversary will not move while in gear
Easy to explain, crank up ...put in 1st or any other gear...step on gas...revs up and no movement. I am thinking something came loose etc
Thanks |
Re: 1997 z28 30th anniversary will not move while in gear
Usually not a lot of tech help here in the "Lounge"..... I'll move this to the "Drivetrain" forum for you.
Assuming it's a 4L60E, have you scanned the PCM for transmission codes? Most of them don't turn on the SES light. Does the shift lever have any resistance? Did you check the cable? |
