What front springs with the Hal's?
Old Oct 24, 2003 | 10:36 AM
Z-RATED94's Avatar
This is for you die hard drag racers. I could use some advice on what front springs to use. Right now I have the Eibach's front and back with stock shocks. Great for handling and the lowered look but BAD for weight transfer. The car also has KBDD sfc's, lca's, relocation brackets and a Spohn adj. TA. Iv'e removed the front sway bar and put some Nitto DR's on, but that only seems to help on the street, not at the track.
What front springs would you use with some Hal shocks? Stock, V-6, Hal drags? I'd like to keep the Eibach's on the back and be able to adj. the Hal's for a slightly raked look. What do you guys recommend?
Oh yeah, the car also has a airbag in the right rear.
Thanks, Rick
Old Oct 24, 2003 | 02:12 PM
TedH's Avatar
I am using the Eibach Drag Springs...
Old Oct 24, 2003 | 02:27 PM
HungryT/A's Avatar
tnthub,
I alway
Old Oct 24, 2003 | 02:32 PM
HungryT/A's Avatar
tnthub,
I always wanted to know more about these Eibach Springs! Are they softer than stock? Do they lower the car?
What do you say: 4 Hal shocks with hal springs in the front and stock rear, or 4 Hals with 4 Eibach drag springs? Thanks!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
KYWes
Apr 3, 2015 07:59 PM
ModdedNerd
Dec 25, 2014 05:51 PM
