Track Times Ok?
Old Nov 26, 2007 | 11:05 PM
red_94z's Avatar
Track Times Ok?
I don't have a tune,(its mail order) intake,(still LS1) or the racing rims n really sticky tires YET, but do you guys think the times in my sig are alright for the car?
Old Nov 27, 2007 | 08:02 AM
AL SS590 M6's Avatar
Moderator
What were the weather conditions and elevation of the track? And what's your race weight?
Comparing your setup to mine you have better heads, bigger cam, built short block, higher compression ratio.
And you're about 4 tenths and 4-5 mph slower. Your 60' is decent so that's not a problem.
I run at a track with 700' elevation and the DA was 1260' for my 10.97 run. And my car weighs 3340/me.
If your weather/elevation was way worse then your time is ok. If not then get a good dyno tune.
Old Nov 27, 2007 | 02:54 PM
red_94z's Avatar
Well I honestly don't know what the DA was. It was around 35 degrees I think, and the elevation is probably around 500 feet.... So basically my times suck lol
The race weight is 3630 with me in it.
Old Nov 27, 2007 | 05:08 PM
The Engineer's Avatar
Those 60ft times down in the 1.5s are nothing to sneeze at (great)! Also, your 1/8 ET translates to a 11.50 1/4 mile. So, very good for a street car!
WD
Old Nov 27, 2007 | 06:22 PM
TrickStang37's Avatar
they dont suck your car also weighs 300lbs more than his. On top of that, youre comparing different tracks on different days.
Old Nov 27, 2007 | 08:58 PM
red_94z's Avatar
Thanks guys, but they could be better....
Oh, well its still a work in progress. i though it mighta been a lil slow. heh
Old Nov 28, 2007 | 07:48 AM
Moderator
That's why I started out asking questions rather than bashing his time. I know how much track and weather can effect times.
Old Nov 28, 2007 | 07:53 AM
Moderator
Take off the 300 lbs. and that would put you around 7.06 @ 94.5mph which doesn't suck.
Put a real drag tire on the back (I use Hoosier Drag Radials) and get a good tune and you could maybe shave a tenth or 2 off of your numbers.
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Jan 25, 2015 12:22 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
GRN96WS6
Sep 8, 2002 10:45 PM
teedoff59
Aug 8, 2002 01:36 AM
