Sway at high speeds
Old Apr 5, 2005 | 03:36 PM
PANZ28's Avatar
Sway at high speeds
I use M/T ET streets at the track and usually run about 15-19psi in them. After the 1/8th mile point once my car starts hitting higher speeds, it starts swaying left to right in the lane. Why is that? Sometimes I actually let off the gas cause it gets pretty bad. Most of my suspension is done but I don't have a torque arm. Would that help? Thanks.
Old Apr 5, 2005 | 03:45 PM
kazman's Avatar
Re: Sway at high speeds
Retork all the rear supension parts. Something seems loose to me.
Old Apr 5, 2005 | 06:02 PM
Capn Pete's Avatar
Do you run bias-ply FRONT tires when you put ET Streets on the back?? If not, that's why. When you run radial tires and bias-ply tires on the same car, they don't act/react the same, and you'll get that "tail wagging" sensation. We ran my Dad's '73 that way last fall, and it's not really great to drive (technically, it's actually illegal to drive on the streets that way!! ).
If you want your car to handle properly, either get Drag Radials (Mickey Thompson now makes those too) or get BF Goodrich or Nittos. Otherwise, get a set of bias-ply front tires, and it'll correct that problem .
Old Apr 5, 2005 | 10:04 PM
Spinner's Avatar
Get used to it
Old Apr 12, 2005 | 02:49 PM
andy katzelis's Avatar
Rubber suspension mounts can allow excessive movement. I've also had trouble with high speed stability with a posi unit, spool fixed that.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
Mar 13, 2016 03:39 PM
8T8IROC
Mar 26, 2015 09:02 PM
siguy
Nov 27, 2014 10:07 AM
