New best and finally a good 60ft.
I finally got to run the Z last night since the my first outting with it in the beginning of July. Since then, I raised the front end of the car up about an inch, adjusted the wolfe sway bar, and put on some 26x11.5 ET streets.
The first pass it sun for a split second and hooked but I hit the rev limiter in the top of first gear due to the inaccuracy of my factory tach with caused me to lose MPH(I had to take out my Monster tach and shift lite to get it recalibrated). 60ft. 1.658 330ft 4.867 660ft 7.593 mph 91.33 1000ft 9.934 1/4 11.886 mph 116.05 Second run I tightened up the rear suspension a little and launched a little softer which caused the car to bog. 60ft 1.773 330ft 5.046 660ft 7.765 mph 91.01 1000ft 10.081 1/4 12.011 mph 117.31 On all the runs the car seemed to die when I would shift into the next gear. I think I may be getting some knock but my laptop took a crap so I am not able to log it now (solid motor mounts/ banging 4" exhaust might be causing this). Hopefully that is the only thing that is causing it to run 3-4 mph less than expected. The car did run 3 tenths faster with no engine tuning and only changing the suspension. Hopefully once I get it tuned in it will run an 11.3@120-121mph...Now I just got to find the last 3-4 mph out of tuning the engine. Later Matt ------------------ 96 Camaro Z28 6spd., T-tops, custom viper red with pearlcoat paintjob, 355 LT1 11.5-1, GTP stage 2 LT4 heads/intake, GTP-6 cam, full cage, moser 9" with 4.11's, full suspension, and too much other stuff to list. Best so far after shakedown runs...still needs tuning and suspension tweaking. 1.754 60', 12.137@116.07, 7.848@90.53 1/8 mile The Z under construction 92 Talon TSI 5spd. AWD Best E.T.-13.753@98.30mph 1.885 60ft.@13lbs boost--- For Sale! |
