How much does a Spohn Driveshaft weigh?
How much does a Spohn Driveshaft weigh? I am going to need a driveshaft and I want something that will just bolt in instead of having to measure and stuff. I am thinking about the Spohn Driveshaft but I dont want it if it's too heavy.
------------------ 1980 Camaro Z28 Sikkens 3 Stage Blue and Purple 1994 Camaro Z28 Teal M6 Ported Heads, LT4 Hot Cam and Springs, 1.6 RR's, Mac Headers and Offroad Y Pipe, Flowmaster Catback, Resonators, Flowtech Cutout, NX 150 Horsepower Shot of Nitrous, NX Bottle Heater, NX Remote Bottle Opener, NOS Purge, KB DD SFCs, BMR STB, Hypertech 160 Thermostat, Redline Water Wetter and Synthetic Diff. Fluid, McLeod Dual Performance Clutch, K&N FIPK, LT4 KM, 1LE Bellow, Holley 58mm Throttle Body, TB Coolant Bypass, Metco Valve Cover Breather, LPW Rearend Support Cover, Strange 3.73s, Eaton Posi, TA Stud Kit, Lakewood LCAs and Adjustable Panhard Rod, LS1 Driveshaft, March Underdrive Pullies, MSD 6AL, MSD Window Switch, MSD Blaster Coil, NGK TR6's, Mobil 1 Synthetic, Pro 5.0 Shifter, Intrax Lowering Springs, BFGoodRich Comp TAs 255/50/16, Nitto Drag Radials 245/50/16, AVS Blackouts on the back. 339 RWHP Corrected with two broke rings 465 RWHP Corrected on the nitrous with the clutch slipping bad and two broke rings www.geocities.com/speeds8erm1 |
It's been so long since I put mine in I forgot. IIRC, it weighs a little more than the stocker(larger diameter, made of steel).
It weighs a little more than a stock steel driveshaft?
I seem to recall mine being significantly heavier than a stock steel DS, but 1350 yokes aren't necessarily light.. I never really worried about the weight of it too much, I just wanted something that won't break. If I had it to do all over again, I'd probably get a chromoly shaft from Denny's. I got Spohn because he did most everything else for me..
------------------ ...Brady Twin Turbo 1996 Z28 Sponsored by YearOne '98 B4C Camaro <--- FOR SALE |
It wouldnt be that big of a deal if I wasnt going to have to scrape up every little bit of power with this setup. http://web.camaross.com/bb/smile.gif I might get a Mark Williams or Moser because I am having to buy a driveshaft with store credit I have and they cant get Spohn.
