Helmets - $150 the least?
Old Apr 24, 2003 | 08:37 AM
Dave 96TA's Avatar
Time to buy a helmet so i can stop borrowing from other people. Cheapest helmet I can find is $149.99 over at Jegs for a G-Force open face SA00. I know, I know, if your brain is only worth $150...blah blah. But I make it to the track maybe 4 times a year and at the local track get maybe 2 or 3 passes per night. So spending $450 to use the helmet 12 times a year isn't gonna happen. Anyone have a better source for a legal brain bucket?
Old Apr 24, 2003 | 09:05 AM
TedH's Avatar
Try a local cycle shop. A helmet with a snell 2000 or 95 rating will be fine. It isn't just you, its for the guy in the other lane too that can cause all kinds of trouble at the big end of the track. Nothing like hearing chutes pop on a dragster as you cross the lights.
Old Apr 24, 2003 | 09:17 AM
GREGG 97Z's Avatar
I got a nice new open face black motorcycle helmet with the snell 2000 rating at a local cycle shop for $89. I've used it at several tracks and it passes fine.
Old Apr 24, 2003 | 10:50 AM
Dave 96TA's Avatar
Now is that the Snell SA2000 (SA00) or the Snell M2000 (M00)? Tracks I'll be at require SA2000 (though many pass with SA95).
Old Apr 24, 2003 | 11:03 AM
GREGG 97Z's Avatar
I'd have to 2x check it but I know it passes at three tracks I've run at around here including Maple Grove raceway which is a big NHRA track and their tech inspectors are pretty **** about such things
Old Apr 24, 2003 | 01:31 PM
DarkHorse's Avatar
Summit has them for $99. Check their website they should be on there. They're in the catalog for sure
Old Apr 24, 2003 | 11:28 PM
Stephen 87 IROC's Avatar
If your track says you need an SA rated helmet, ask them where in the rule book does it say that. Even ProStock cars only require an M rated helmet but they all use SA ones.
There's no reason a car running slower than 9.99 requires the extra expense of buying an SA rated helmet when the rulebook says an M rated one is all you need. There are a couple of exceptions but they don't affect your typical street car or bracket racer.
Check you local motorcycle shops for an open face M2000. The M95's should be a lot cheaper but are already getting old. If you buy one, you'll need to buy another helmet in less than 10 years. M90 is the minimun but they'll expire in a couple of years.
Some tracks require you to have a helmet at all speed. That's a track policy but having to be SA rated shouldn't be.
I don't have a 2003 rulebook handy but in the 2002 NHRA rulebook:
Helmet: Drivers in 13.99 or quicker cars must wear a helmet meeting Snell 90, 95, K98, 2000 or SFI 31.1, 31.2, 41.1, 41.2. Drivers in supercharged, front engine, open body cars and funny cars need the SA rated helmet.
SFI 31.1 = Snell SA open face
SFI 31.2 = Snell SA full face
SFI 41.1 = Snell M open face
SFI 41.2 = Snell M full face
A Snell K98 (Karting) helmet is acceptable in place of any Snell M rated helmet.
For more information on Snell ratings you can check out www.smf.org
Old Apr 25, 2003 | 09:01 AM
Dave 96TA's Avatar
This is what it says on their website: "13.99 or quicker must have Snell 90, 95 or 2000 helmet." SA and M are both Snell ratings...so would one assume they're both legit for 12s and 13s in a street car?
Old Apr 25, 2003 | 07:43 PM
Yes.
All tracks go by the rules and state you need a Snell rated helmet. That means an SA or M rated helmet is accepted plus a K98 rating. Just make sure there's a Snell label on the inside of the helmet. Only a decal on the outside isn't accepted.
If it's not Snell rated, then it's not acceptable, at least below 13.99. Other helmets might have an ANSI, DOT or CSA rating among others. If they don't have a Snell rating, you won't be able to use them.
So go price out a M2000 open face helmet from a local motorcycle shop. They're a lot cheaper than having to buy an SA rated helmet. Even try asking local racers if there's a place that sells helmets at a discount to racers. We have a local bike shop, the owner races a bike, who will sell racers a new helmet at cost plus 10%.
Old Apr 29, 2003 | 03:32 PM
Dave 96TA's Avatar
great info thanks Stephen
Old Apr 29, 2003 | 08:44 PM
The main differences between a SA and M rated helmet
Inner lining:
SA: Cotton (doesn't burn as easily)
M: Usually nylon
Impact testing:
SA: Tested against round objects such as roll bars.
M: Tested against flat objects such as pavement
Face opening size:
SA: Smaller opening to better protect the face
M: Larger opening so you have a wider field of view. ie. riding on a motorcycle.
13qtr
Oct 28, 2016 08:11 PM
LT14LIFE
Nov 15, 2015 06:22 PM
form94
Sep 23, 2015 07:30 AM
Henson071
Sep 18, 2015 04:01 PM
Sep 17, 2015 11:53 AM
