First timer going to the track tomarrow, any advice?
Old 01-13-2004, 10:53 PM
Got-LT1's Avatar
I know about not going through the waterbox and such, any tips on setting up the car? Tire psi and such?
Got-LT1 is offline
Old 01-13-2004, 11:50 PM
faded93bird's Avatar
Don't stage with the rear tires
faded93bird is offline
Old 01-14-2004, 12:59 AM
Got-LT1's Avatar
seen that done many times by the ricers up at englishtown in Jersey. Funny stuff.
What RPM should I powerbrake up to?
Got-LT1 is offline
Old 01-14-2004, 09:51 AM
just pull it up on the converter as far as you can ( with out breaking the tires loose ) and play with your luanch from there.
As for just ricers staging with their rear's. Sometimes you just dont see those double yellows flash when you roll through them the first time
Most of all have fun and if it's your very first time dont worry about your proformance, getting better just takes practice
Faded
Old 01-14-2004, 04:23 PM
TedH's Avatar
Let the tech guys know it is your first time.
Ask questions. There are no stupid questions.
Have a good time.
As a very general rule of thumb, 20-24 PSI in the rears works for me on street tires. I usually put about 40 pounds in the front. Bring shoe polish, helmet, wear your seatbelt and keep your window up. I usually launch off idle. When the second yellow bulb comes on, floor it.
TedH is offline
Feffman
10-09-2015 05:44 AM
Feffman
10-09-2015 05:42 AM
Feffman
07-02-2015 06:52 AM
Feffman
Events and Cruise Spots
06-04-2015 05:44 AM
PublicEnemy1
04-07-2015 12:21 PM
Quick Reply: First timer going to the track tomarrow, any advice?
