Do Skinnies make any kinda of a difference?
Old Jul 8, 2003 | 01:35 PM
95 Silver TA's Avatar
I wanted to know if there would be any gains at the 1/4 track from changing my 17Ss rims in the front to Skinnies. If so, what kinda of gain am I looking at a tenth or not even.
I heard/read that 100# lighter will give you about ~ a tenths
and so will every 10 HP.
Just curious..
Claude
Old Jul 8, 2003 | 02:04 PM
TedH's Avatar
Lighter weight ( off the front which is extra good), and less rolling resistance. Also, I went for a 28" tall front tire as well to increase the rollout.
It is difficult to quantify the actual amount of improvement because I changed all four rims at the same time.
Old Jul 8, 2003 | 08:15 PM
Thanks for the response
Has anyone slap skinnies on there cars and noticed a specific drop in ET or gain in MPH from thier old set up?
Again, I am just curious to see how much they do help.
Thx,
Claude
Old Jul 8, 2003 | 08:29 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
yes, it helps a lot. prolly .1 and 1.5mph easy over heavy 17s
Old Jul 8, 2003 | 11:20 PM
95Bird's Avatar
changed em on my wifes lt1 at the track...ran 3 times with 17" fikse rims...then put on the skinnies..ran 3 times..average of .17 . Can't remember the mph increase but I think right at 2 mph
Old Jul 9, 2003 | 12:47 AM
94 TA TT2S's Avatar
Same results here almost 2 tenths.....you are not only losing weight were you need to for transfer, you are as stated above reducing rolling resistance...I gained about the same from my TT's to Centerline warriors and weld draglites
Old Jul 9, 2003 | 01:57 AM
AL SS590 M6's Avatar
Moderator
I gained about 1 tenth and 1 mph going from stock 16 x 8" wheels and GSCs to 3.5 x 15" Bogarts with metric radials. I only changed the fronts for now.
Old Jul 9, 2003 | 07:00 AM
Wow thats a pretty big difference....Thanks A Bunch Guys for all the great detailed responses...Its Much appreciated!!
Claude
Old Jul 9, 2003 | 08:36 AM
Redbird's Avatar
Arrow Losing weight...
ESPECIALLY weight that rotates and contacts the ground, is the best weight to lose. It is worth several more time than taking out static weight. Remember... one of the first things after the drive train to start movin are the wheels. Making them lighter makes 'em move quicker! Light wheels and tires... ALWAYS a good investment. If you can afford it run DRAG front tires and not radials, they are lighter yet, but like 3 times the cost!
HInk
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Jeff1904
Jan 3, 2015 12:00 AM
