Not happy with my times! can you help?
Old 07-22-2012, 08:29 PM
meangreenchevy's Avatar
I went to my local track for the first time on my new set up and I am not happy with what it ran. Its an lt1 bored to a 355, cc503, heads are ported with bigger valves, ported intake, cutout and all other bolts ons. Stock rear with 3.42s. Tires are 275/40/17 street tires(I think there riken raptors). Check engine light came on as soon as I got to the track for a p1133 code(o2 sensor b1 sensor 1 insufficent switchs). My best was a 13.5 at 107.5 with a 2.2 60 foot. What's going wrong?
meangreenchevy is offline
Old 07-23-2012, 05:20 AM
Re: Not happy with my times! can you help?
What is the elevation of the track? What were the weather conditions - air temp, humidity and barometer? What fuel were you running?
Injuneer is offline
Old 07-23-2012, 05:13 PM
Temps were mid 70s not too humid. Elevation I don't have a clue lol my local track is englishtown raceway park. I run sunoco 93
Old 07-24-2012, 10:37 AM
Steve69SS396's Avatar
Theres your problem. You've got the MPH for mid 12's but you have no traction. Put some good tires on it.
Steve69SS396 is offline
Old 07-24-2012, 12:44 PM
I want to get a set of hoosier quick time pros but I'm scared of the stock 10 bolt. I was gonna get a set and go towards the end of the season with the drag radials and launch at about 4k and hope the rear holds for 1 pass
Old 07-24-2012, 04:48 PM
kazman's Avatar
You might find more traction at Atco.
kazman is offline
Old 07-24-2012, 06:06 PM
Atco is a better track I here but a little far for me
Old 07-24-2012, 06:30 PM
kazman's Avatar
I recently moved to SW florida. Closest track is an hour and not open a whole bunch. Next closest is 2 hours, then 3.5. I'm planning to race in NC over Thanksgiving...that's a 13-14 hour one way haul.
Atco is worth the drive.
kazman is offline
Old 07-28-2012, 06:19 PM
transamtom's Avatar
Is it an A4? or M6?
With an A4 you don't have to worry about the rear end as much.
Get some DR's the sticky Mickeys work well.
transamtom is offline
Old 07-29-2012, 07:30 AM
Its an m6 and we all know what happens with a sticky tire an m6 and a stock reat
Old 07-29-2012, 10:49 AM
transamtom's Avatar
Only if you drop the hammer at 3,000rpm+
Old 10-18-2012, 09:42 PM
Stardust's Avatar
60' is a killer.
I am 2.12-2.14 bone stock with goodyear street tires.
Stardust is offline
Old 11-27-2012, 09:34 AM
EddieB's Avatar
Get a decent set of drag radials and give it hell. I was leaving the line at 5500 rpm with 450 rwhp on a 7.5 ten bolt moser axles, 4.56 gears and mt et streets. Never broke.
EddieB is offline
Old 04-27-2014, 05:35 AM
standonit's Avatar
Please don't respond to that post I know what that meens and I have a M-6.
standonit is offline
Old 08-01-2014, 07:32 PM
HardcoreRM125's Avatar
Everyone is getting caught up on the 60' time. You can have a bad launch and still MPH the **** out of a run.
Quite frankly, I think his MPH is pretty low for a heads,cam,bolt ons, tune car. He should be in the 108-112MPH range. I suspect the car is running poorly with it setting an O2 code. Never wrenched on a car yet that had a bad O2 sensor and didn't get poor power, horrendous mileage, etc.
Your Air/Fuel mixture is probably pretty out of whack with a bad O2 sensor. Don't waste your time with a Bosch unit. They suck. Stick with AC *****.
And everyone that is going to say that at WOT, it bypasses the O2's ... yes. It sure does. But the severely split BLM's it probably has now, is what it corrects the WOT fuel trims from. So the mixture is still wrong.
Fix it, get it to stop setting codes. Replace both O2's with AC Delco's. And maybe try launching it a little harder on a stickier tire.
My $0.02's
HardcoreRM125 is offline
Quick Reply: Not happy with my times! can you help?
