A4 guys how do you drag?
Old Jul 6, 2003 | 05:07 PM
chevyboy_z28's Avatar
do you hold the brake and torque it up a little (not breaking the tires loose tho), or do you just jam it from idle, or do you kinda ease into it and then jam it? i have tried all of these techniques but seeing as how ive never been to the track i really dont know what works best, so any pointers would help? it seems like everytime i torque it up and preload the rear i get a little better jump off the line, but most of the time i end up spinnin em and gettin a little sideways action, but when i go from idle it seems a little slower off the line, but doesnt spin em. what works best for you guys.
also does racing in drive or overdrive make any difference (most of the time i go from drive)?
Old Jul 6, 2003 | 05:23 PM
RacinLT1's Avatar
i leave mine in drive. I run a sticky tire,so i usually stall it up,then mash it.
Every car is different,it takes practice to feel out what your combo wants.
Old Jul 6, 2003 | 10:42 PM
Antz97ZNJ's Avatar
Put it in drive stall it up n hit it....dont punch it you'll go up in smoke...takes some timming practice
Old Jul 7, 2003 | 01:09 AM
94GrayV6's Avatar
Doesn't matter if it's in D or OD, if you're at WOT it isn't going to shift into OD anyways. I usually stall it up a little, then roll into the throttle. It's definitely a dance you have to learn.
Old Jul 7, 2003 | 01:22 AM
kostya_f's Avatar
with the stock converter/gears and steet tires at the track i have enough traction to just nail it/flash the converter.
Old Jul 7, 2003 | 11:43 AM
yea i was thinkin the same thing, especially with a 2.73 rear, me and traction should be best friends, but more than likely my problems are coming from the tires and their lack of meat !
Old Jul 7, 2003 | 03:55 PM
TobyZ28's Avatar
My A4 will shift into OD on WOT and wont in D... ???
Old Jul 7, 2003 | 06:22 PM
94GrayV6's Avatar
Maybe if you trap high enough to get all the way through 3rd gear, but those of us with bolt-on cars aren't trapping 120 or anything. Maybe if you have 3.73s or something...
RUENUF
May 25, 2016 08:10 PM
carguy0119
Apr 11, 2016 11:11 PM
RUENUF
Mar 13, 2016 03:39 PM
Moshbmx1
Jan 20, 2015 03:27 PM
Red97LT1
Aug 7, 2002 05:45 PM
