89 formula vs 95 formula
my brother and i will be heading to the track this weekend and just figured i would put this up to see what everyone thinks will happen.
89 formula 3150 race weight, iron headed lt1 2.02 1.60 valves home port and polish,502 cam, gm pro carbed lt1 intake, 2'', spacer holley 700cfm mechanical secondary double pumper,t5,373 posi, on 245 5016 street tires VS 95 formula 3500 race weight, cold air, 52mm tb, pasesetter mids dumped at axle, 1.6rr, 700r4, 2700 stall, shift kit, 342 posi, on 255 60 15 mt et streets so what do you think do i have a chance? |
Depends on his tires and trans. If he can't hook and/or shift a manual then you have a chance.
If he has an auto and good tires just watch the pretty taillights.:) |
89 if he has the tires that hook ;) But if not and he can leave from idle and shift good your done :D
I think your going to win. Good luck
