60' to 1/4 mile correllation question.
Old Nov 16, 2004 | 10:46 AM
LameRandomName's Avatar
At the risk of oversimplifying this question...
If your ET numbers are higher than your 60' times would imply they should be, what is going on?
Actual Numbers:
60' = 1.85-ish
1/4 = right around 14.00 (Best of 13.998 @ 95.648mph)
MPH = 95.5-ish
Is this a heavy car phenomenon (~4500lb with driver) or is it a gearing issue?
FWIW, this is on 26x10 M/T ET Drags with what felt like a fairly decent hook.
Old Nov 17, 2004 | 03:01 PM
five7kid's Avatar
Re: 60' to 1/4 mile correllation question.
Weight should slow down both the 60' and 1/4.
Are you sure you aren't having fuel problems at the top end?
Old Nov 17, 2004 | 11:49 PM
No, I'm not sure.
I think I'll send out the heads this winter, and do a Walbro 255 swap.
Plus some dyno tuning.
I wasn't planning on doing anything with the motor this winter, but I feel like there's a lot left in the car; if I look for it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
