1/4mile Times!
Subscribe
Sep 27, 2009 | 07:16 AM
I finally got my car running and to the track. First pass was 16.2@105 second pass 14.75@106 spinning and sideways at the 1/8th on both. Got smart and dropped tire pressure from 32 to 17 1/2. Third pass 13.3@88, the trans didnt want to shift :/ Fourth pass 13.15@112 playin the throttle and spinnin past the 60'. Final pass 12.9@113 again playing the throttle and spinnin past the 60'. Need to get my slicks! Thinkin I can get a 12.7@114 on street tires next time out
Reply
Sep 27, 2009 | 02:13 PM
Slicks or maybe a set of MT drag radials. What gear are you running? Nice times your running there. With that mph you could be down in the 11.80-12.20 range as long as your not racing in some crazy high DA.
Reply
Sep 27, 2009 | 07:32 PM
I have a set of slicks already mounted with 2 passes lined up for $200 just have to have them shipped here. Stock 3.23 gears. I currently live in Sacramento, CA. I see your out of Illinois, ever heard of Metropolis?
Reply
Sep 28, 2009 | 02:59 AM
Good to see you got it out there! That's an 11.90 car!... I'd guess 116-118mph.
Reply
Sep 28, 2009 | 07:21 AM
Thanks. Yah we were thinkink high 11's. Can still do some more work on the heads, get a bigger stall, and maybe a custom cam. That should be good for around 500 rwhp. Actually shouldn't need a different cam. Going to work on the suspension and rear-end first.
Reply
Sep 28, 2009 | 03:41 PM
Quote: I have a set of slicks already mounted with 2 passes lined up for $200 just have to have them shipped here. Stock 3.23 gears. I currently live in Sacramento, CA. I see your out of Illinois, ever heard of Metropolis?
Shipping those is gonna cost you big time, but sounds like a good price. Metropolis, can't say that that rings a bell.
Reply
Sep 28, 2009 | 03:46 PM
southeast corner..ive got a couple buddies from there. and apparently shipping shouldnt be more than 50 which still makes it a good price.
Reply
Oct 5, 2009 | 01:40 PM
if you get those 60fts in order (1.8x or lower) and you should have a low 12/ high 11 second car. Did you take off the front sway bar? Weight reduction?
Reply
Oct 5, 2009 | 04:56 PM
no i didnt take off the front sway bar. the car has no ac, power steering, carpet, sound deadening material. on the important side its all stock suspension with eibach prokit springs so im working on changin that.
Reply
Oct 5, 2009 | 06:58 PM
is it tuned for the stall?
Reply
Oct 5, 2009 | 07:26 PM
Quote: Thanks. Yah we were thinkink high 11's. Can still do some more work on the heads, get a bigger stall, and maybe a custom cam. That should be good for around 500 rwhp. Actually shouldn't need a different cam. Going to work on the suspension and rear-end first.
Maybe i'm a pessimist but I do not see anywhere near 500whp coming from that.
Reply
Oct 6, 2009 | 08:18 AM
i said around to indicate a VERY rough guess at potential....and yes i can get close....theres a lot left in the heads even keeping this cam...and i would be going with a different cam as well
Reply
Oct 6, 2009 | 08:20 AM
ohhh and i might be picking up a 10 bolt with 3.73s and only 20,000 miles as well as some new shocks for next to nothing so that should help some at the track.
Reply
Subscribe
