CamaroZ28.Com Message Board
-   Computer Diagnostics and Tuning (https://www.camaroz28.com/forums/computer-diagnostics-tuning-36/)
-   -   VSS Diagnostic question (https://www.camaroz28.com/forums/computer-diagnostics-tuning-36/vss-diagnostic-question-882559/)
MichiganSkip Jun 8, 2015 10:30 AM
The older version of TC that I used to use, had a table for setting VSS Diagnostic enable by rpm. This new version doesn't
However, I see 2 switches for VSS diagnostics in the switch table. Is turning them off the same as setting the rpm to > 3000 to keep from going into limp home mode with a higher stall converter?
