Tunercat connection issues
I have a 95 z28 that has the obd1 computer, but an obd2 connector from the factory. When ever I try to do flashread with tuner cat, the com port will not open. We use the same program on a 91 with no problems, and a 91 vette as well. I've tried it in DOS and windows with no luck. Why can't the laptop communicate with the pcm?
------------------ James 95 Z28 M6 -355 forged 11:1 motor and Nitrous Works Wet kit 125 shot :) |
Are you sure your cable for the 95 is good? I had the same problem and it turned out I had the ground wire soldered incorrectly in my homemade cable. Good luck.
| All times are GMT -5. The time now is 09:58 AM. |
