Trouble finding injector voltage offsets for Bosch EV6 (0-280-155-831)
I installed a set of Bosch EV6 31.8# injectors in a 94 Formula and am working on updating the tune using TunerPro. These injectors (0-280-155-831) are rated at 31.8# at 55psi, so at 43.5psi the flow rate works out to 28.26.
What I can't find is a voltage curve so I can update the "Injector Voltage Offsets" table. Going from an EV1 to an EV6 injector makes me think there could be a big enough difference to cause problems if I can't get close. Anyone have a datasheet for these injectors or know where I might find it? |
