Torque Management
IS it necessary to remove Torque Management when I have my new TCI 3500 TC installed
I believe so.
Is it possible to remove it without LS1 Edit?
No it is not.
ok i guess thats another 50 bucks i have to spend
id have it removed.major difference,firms up your shifts.
No, you do not have to have it removed. It makes a minor difference in your track times - maybe .05 - and no difference in around town driving. And it does not "firm" up your shifts ...
how come mine shifts harder?:confused: guess im imagining it.
You can get it remove with a Predator, talk to James@RWTD.
You want it gone, because it regulates your line pressure. I know a guy from P'Cola that didn't take it off when he put a TCI 4000 in, and the computer thought it was a stock tranny slipping, so it upped the line pressure so much the thing went BOOM!
Definately get her GONE ;) |
Originally posted by RS Dragster You want it gone, because it regulates your line pressure. I know a guy from P'Cola that didn't take it off when he put a TCI 4000 in, and the computer thought it was a stock tranny slipping, so it upped the line pressure so much the thing went BOOM! Definately get her GONE ;) TM doesn't have anything to do with line pressure. Originally posted by RS Dragster how come mine shifts harder? guess im imagining it. What you're describing as "firmer" shifts is the automatic equivalent of power shifting in a manual ... if you stay in the throttle during a shift it will feel "firmer". People were putting high stall TCs in these cars for years without removing TM and without problems ... then LS1edit came out and someone decided to remove TM and picked up a little ET at the track ... so everyone jumped on the bandwagon. So now 90% of the internet community, who has limited knowledge of what TM is or what it even does, is perpetuating the myth that TM "must" be removed if you are running a high stall TC ... even worse you'll damage your tranny if you don't ... when actually the opposite is true ... |
thanks for all the replys so will there be any noticable gains with it off then on
Originally posted by the1turkey thanks for all the replys so will there be any noticable gains with it off then on |
To Put it simple , It pulls out Timing when the tranny is shifting Gears.
Also I see you have a '98 so its not as bad as the '01 and '02 models. TM has affected my car only like 3 times (not shure why no TC or big mods) but it seems on a hard launch it would pull good for a few seconds then just fall flat for a second and pick back up?? I only assume this is TM never checked it with edit or any other program
| All times are GMT -5. The time now is 08:14 AM. |
