is there anyone who has put a 94 wireing harness in a 93
Old Jan 13, 2008 | 06:16 PM
93camarochrisz28's Avatar
and what does it take to install it?i know you have to re wire a little bit i just want to know what has to be cut to make work you know what that is and the 94 is not a maf it is still speed denstey right
Old Feb 13, 2008 | 08:54 AM
My93Z's Avatar
A 94 is a MAF car not speed density.
Old Feb 13, 2008 | 04:09 PM
A 93 is speed density (no MAF as noted above), and runs batch fire injectors (one wire from the PCM to each bank of the engine, firing all 4 injectors simultaneously). A 94 harness with have the connector for the MAF sensor, and 8 individual injector wires, because the 94 runs sequential injection (one injector at a time, based on cam position). I think there may be a minor difference in the IAC motor connection as well. 93 has no tranny controls, 94 harness will have the electronic connections for the A4 or M6 transmisions. 94 will have 4-wire heated O2 sensor connectors, 93 has single-wire unheated O2 sensors.
You would have to modify the injector wiring to allow the 94 harness to work with a 93 ECM. You can convert a 93 to heated O2 sensors. You could leave the MAF plug hanging loose.
Old Feb 13, 2008 | 08:20 PM
2xLS1's Avatar
I know someone here in Okla City that did it. I believe he used a Speartech reworked 94 harness and a 94 PCM. He is running a MAF also. He has a box that plugs into the transmission connector that keeps from setting the transmission codes because he is still running the 93 4L60.
Old Feb 14, 2008 | 10:02 AM
yeah i talk to the guy from speartech yesterday and he said he is going to help me out this is just to much for me to get in to now i really dont want to mess anything up
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
$hawn
Aug 3, 2002 04:59 AM
CobraEatr
Jul 23, 2002 06:32 PM
