Scanmaster code 61
On my 95' I get a Code 61 and the A/C compressor stops working. I know the code is A/C performance but I cannot find a reason for the code when searching. If I pull the PCM fuse and replace, the A/C will work for a short time until it throughs the 61 code and shuts it off. Low side pressure is ok and system seems to work fine until it sets code and shuts off.
What causes the code to be thrown? any way to diagnois the problem? Thanks, Kevin |
Your AC charge is low.
Dan |
