Scan9495 Observations?
Old 07-28-2018, 04:10 PM
  #16
KYWes's Avatar
Re: Scan9495 Observations?
Guess I better start shopping around for an ECM.
KYWes is offline
Old 07-28-2018, 04:29 PM
  #17
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Originally Posted by Injuneer
Another piece of the puzzle, possibly pointing to the PCM.
In several instances, the end of the defective data line shows DTC 86. I assumed this was just a bogus code, because it isn’t referenced in the factory manual. But I did a Google search on GM OBD1 Trouble Code 86, and found it is a code (at least in some other vehicles) for:
https://repairpal.com/gm-obd-code-86
KYWes: is the engine experiencing any noticeable “hiccups” that might correspond to these data faults.
Weird. At first I would have written that off as a glitch, but every time the 86 code appears, the next line shows one (1) trouble code. Never seen anything like that.
GaryDoug is offline
Old 07-28-2018, 04:33 PM
  #18
KYWes's Avatar
Yes, I think there are some momentary anomalies like idling burps from what I remember.
KYWes is offline
Old 07-28-2018, 04:42 PM
  #19
Prominent Member
GaryDoug's Avatar
If you can run another scan with the Comms screen enabled, save the Comms screen results to file, and post it, I may be able to see if the PCM is issuing a correct checksum for the bad data. That would really put the blame on the pcm's internal operation.
GaryDoug is offline
Old 07-29-2018, 01:48 PM
  #20
KYWes's Avatar
Gary, here's the Comms data you asked for. I haven't reviewed it yet but when I was logging this run I didn't see the DTC flash red so I'm wondering if the car is being a kid going to see the doctor.;-)
KYWes is offline
Old 07-29-2018, 02:24 PM
  #21
KYWes's Avatar
Here's a second recording. I did see some DTC86s in the corresponding datalog.
File Type: txt
KYWes is offline
Old 07-29-2018, 02:29 PM
  #22
Prominent Member
GaryDoug's Avatar
The problem does show up in this file. The data is being shifted one space to the right randomly early in the data string. I don't know what is causing that, but I doubt it is caused by the pcm. It could just be some electrical noise on the data line or the 12v power to the pcm, a bad cable, or a bug in the program. But I haven't seen that symptom too much before this. The program correctly fails the line with a bad checksum message and restarts the process. Apparently the program does not discard the bad data however. I will look into that.
GaryDoug is offline
Old 12-14-2018, 05:24 AM
  #23
KYWes's Avatar
Gary, wondering if you've had time to research this?
KYWes is offline
Old 12-15-2018, 07:46 AM
  #24
Prominent Member
GaryDoug's Avatar
Nope. Can't seem to duplicate it.
GaryDoug is offline
97'Z-28
12
04-28-2008 11:03 PM
95z28man
04-16-2008 05:28 AM
Craddock
06-09-2006 10:44 AM
kochisp
04-20-2005 02:25 PM
InjectedSS
17
10-20-2003 10:40 PM
Quick Reply: Scan9495 Observations?
